Ok, heres the deal. I'm going friday to check out some heads and figure out a price. Now heres all what comes with it... TFS Twisted Wedge Heads, TFS 1.6 stud mount roller rockers, pushrods or lifters (not sure which ones), and possibly a TFS Stage 1 Cam. The guy wants $950 for everything. I might be able to get him down to $900, or $900 without the cam so is this a good deal on allthe stuff? Everything has somewhere around 5000-6000miles on it. Tell me what you think if everything is in good condition... jump on it, let it pass, or not worth what hes asking and bring him down to what its worth.
Heres some info about the cam:
Characteristics Duration @ .050 in. (Degrees) 221 intake/225 exhaust
Cam Lift (Intake/Exhaust) .312 in./.319 in.
Valve Lift with 1.6 Rockers (Intake/Exhaust) .499 in./.510 in.
Lobe Separation (Degrees) 112
TFS-51402000 Good idle, strong midrange power. Aftermarket intake, heads, and headers recommended. Requires modified mass airflow. Compression ratio: 9:1 to 10.5:1.
And heres some info about the heads:
Combustion Chamber Volume 61cc
Intake Port Volume 170cc
Exhaust Port Volume 66cc
Valve Sizes 2.02 in. (intake) 1.6 in. (exhaust)
Valve Springs 1.470 in. Simgle Springs with Dampers
Valve Locks 7 Degree Machined Steel
Retainers Chromemoly Steel
Rocker Studs ARP 3/8 in.
Guideplates For 5/16 in. Hardened Pushrods
