Show us what you find when you pop the cover off, make sure the cover is not cracked in that area but most times it just an gasket replacement.
Water pump replaced recently?
Y'all do know that there is a tool for this called a coolant pressure tester where you pump air pressure into the radiator and just watch where it squirts out of right?
They mentioned it first thing and I replied back. Pressure tested it a few weeks when smelling coolant. Held pressure, no leak at that time. Found the leak now.
