So do you install the brace, then tack weld the nuts to the tower inside the wheel well area?but weld the nuts to the bottom of the shock tower so you can do a one man install or removal all from the top side.
Either way is fine, but I think the cleaner look in the engine bay would be to weld the nuts to the bottom (once it's all installed and torqued so you know it fits correctly) and then you won't see the exposed thread of the studs when the hood is open.It makes more sense to install the bolts facing up and install the nuts on the top.
Essentially turning them into studs.
Agreed the rear mounting bolts in that cubed spot where the bolt would insert into makes it a real pain!!I've had this issue with the wedge brackets.
The wrench or socket seems to always come off and i crack my hand on something.
Then there is the fact that the bracket and carpet cover the bolt hole making it more difficult.
Let's not forget that the subframe seat brackets get nuts on them, which makes it even more of a pain.
Maybe we are looking at this the wrong way, wonder if it's possible we should be putting the bolts in from under the car, giving them a tack weld so they don't move and installing nuts on the top similar to the studs in the front.
Anybody know if the red version of the car cover is available yet?
Why is it always the nicest looking ones that cost so much..... LOLYou're certainly paying a premium for the Ford Performance Parts name and the Motorsport logos. It does look badass tho, imo.
Car covers.... or women?Why is it always the nicest looking ones that cost so much..... LOL
Based on my 69 years of experience with " those " , the really nice looking ones are NEVER worth the expense...... LOL. or women?
