Expired 4.6 Built Engine From 2006 Mustang Gt
vibora
I have a built 4.6 3-valve, built by Springfield Custom Auto Machine. Less than 50 miles on the motor, installed to heat cycle the motor and dyno (339 HP RWHP)
-11:1 compression
-Bore & Hone Block (w)Torque Plate
-Clean Engine Block
-New Rod Bearing Set
-New Ford 4.6 alum block main bearings
-New Piston Set CUSTOM Wiseco 3cc dome w/rings
-New Ford 4.6 steel I-beam rod
-New Arp main studs 4bolt w windage
-New Valve intake
-New Valve Seals
-New H/L Ford 3v valve spring 4.6-5.4 ands retainer
-New Cam Phasers and timing chain
All are new parts except, block, crank and heads.
Asking $2600.00 or best offer. I have the build invoice for serious buyers.
$3500.00 as a package, I have stock intake and intake delete plates, Pypes long tubes and X-Pipe and JLT CAI.
Mike Rousch can install at his cost.
Depending on the distance, willing to travel to deliver.
Pictures uploaded!
Thanks Noobz
Reactions: 1 user
