Hey guys,
I am in the process of rebuilding a 99 GT. I bought it as a roller, no engine, trans, or anything. I bought an engine from eBay. Turns out it is an NPI block. I put trick flow heads on it and trick flow cams. I also put 24 lb injectors in it. Other than that, it is using stock stuff.
I am trying to get it to run before putting water in it. I have some issue getting a tune to flash, but I am working with American muscle on that.
My question is, should the fuel pressure in the line stay after cranking?
I think something is wrong with the fuel pump. When I turn the key on, I hear the fuel pump and the fuel pressure gauge shows 15 psi, but then immediately drops back to zero. When I crank it, the pressure build to 35-40 psi but as soon as I stop cranking it drops immediately to zero. Should the lines stay pressurized for a little while after the fuel pump builds pressure?
Here is a link to a video of me cranking it over:
View: https://youtube.com/shorts/-2-rWto6nYM
