Basically, yes. But to begin with, if you have a piece of wire laying around, you could somehow jump them from one pin to the other while it's disconnected while someone engages the key.That way you're not needlessly damaging the harness. It also might not be a bad idea to check for current at either of the 2 pins to ensure there are no shorts or breaks in the circuit - that would essentially act the same as the switch not closing and not allowing power to pass to where it needs to go.Yeah I have all my lights and signals and everything. I guess that The NSS is probably the issue then because my solenoid does not actuate when cranking. I can do a little mechanical work but electrical is totally out of my realm of experience and knowledge, when you say jumper the cables do you mean just strip both of them and tie them together? I agree if this does fix the problem just to leave it bypassed because a new switch is like $67 lol.
