Great thread, I must have missed it or else don't remember looking at it.
Cosmetics
Late Model Restoration Mach-1 Grille Delete: Easy install, looks great, and the quality is awesome. I paid $50 for it, and it got here quick. Great company to deal with.
Spring Edition Hood Stripes: Someone took these off my car, so I bought a new set from Late Model Restoration. They came quick, and they are NOT cheap versions you might find elsewhere. Over 2 years and the vinyl looks the same it did the day I applied it. $75.
Tires
Federal Super Steele: They were 245/45/17's. They hooked well for a stock sized tire, and they lasted a while especially running on a bad alignment and using a heavy right foot. These were on the car when I bought them.
General Exclaim UHP: I ordered these from
Tire Rack - Your performance experts for tires and wheels EXCELLENT and fast service. These are 245/45/17 in size, but I am only running them on the front end. Wear has been OUTSTANDING on these tires. They look almost brand new with close to a year on them, and a decent amount of hard driving and a few trips around an autocross track. They work well in rain. My only gripe is when they are pushed really hard they tend to plow a little bit. $86/tire.
Sumitumo HTR-Z: I ordered these from Tire Rack also. Two 315/35/17's. At first, they hooked ok. No better than the Federal 245's that used to be on the car. I accidently ran them over-inflated for a long time, and did some very abuse burnouts and the treadwear has impressed me for what they have gone through. They are allright in the rain when they have tread, but now at the end of their life you MUST drive easy on them almost like a drag radial. Dry traction lacks in all of first and second gear, this wasn't too bad at first but after they wear a little kiss it goodbye. At $99/tire I don't expect much, but these exceeded what I thought they would be.
Drivetrain:
MGW Short Throw Shifter: Smooth as butter! The quality is outstanding on this shifter, you will be hard pressed to find one that can touch this shifter in quality and user adjustability. You can raise or lower the shift handle, and set the angle you want it at. It works only SO/SO for drag racing, but that wasn't really what it was designed for. MGW is a great company to deal with. $190.
Summit Racing 4.10 Gears: I decided to be different and bought these instead of FRPP or Motive gears. Prior to installation, they looked to be very good quality. They were not cast cheaply and were nice and smoothly cut. Since the day of installation these gears have whined. The guy who I had install them is a 35+ year ASE mechanic and has done COUNTLESS other Mustang gear installs for people I personally know. Pinion depth and lash all checked out. We both figure it is just the cut of the gears. We tried to figure out who actually made them (we thought Richmond), as some companies gears are naturally a little noisy. No problems other than that though. They have stood up to 10+ passes at the track, most of which on BIG drag radials launching over 4k RPM. HUGE seat of the pants improvment. I also cut my 1/8th mile times down 2/10ths by switching to these gears. Definatly a first mod if you know where to spend your money correctly. $120 + 300 for install.
Ratech Bearings: I changed the bearings with a fresh set of Ratech's when I had the gears done. I purchased their full bearing kit, aswell as axle bearings. All of them are quality, and are quiet as a mouse in the rear end. Highly reccomend them. Got them from Summit Racing, literally the best automotive company I have ordered from. $100 + axle bearings.
FRPP Trac-lok Rebuild Kit: Got this from Summit also. Comes with all the stuff you need to rebuild your stock limited slip differential, plus friction modifier. I could only see a little bit of difference between performance before and after it was rebuilt. I doubt this was because of bad parts, but more along the lines of the trac-lok not being worn out when I had it rebuilt. $45.
Performance
K&N FIPK: This was on the car when I bought it. It is quiet, and it is made of plastic so there is almost zero heat soak. Highly reccomend it.
Professional Products 75mm TB: This is the non-polished version. Quality is great, I noticed and improvment with throttle response and top end performance when this was paired with a ported plenum. Got it from RPM Outlet with no issues. $225 as a plenum/TB combo.
RPM Ported Plenum: RPM Outlet paired up with C&L to make a lower cost ported upper plenum. It is cast in the same shape of the C&L, but you can tell it is made very cheap. It doesn't have any moving parts, so it's really not a concern. I noticed a nice improvement when paired with the 75mm TB. $225 as a plenum/TB combo.
UPR Catless X Pipe: I bought this used from a buddy of mine. It hangs a little low, but I think it can be tweaked. Quality is great, it has withstood countless encounters with the pavement and isn't torn apart yet. I definatly noticed alot more grunt in the top end with this as opposed to the stock H pipe. This should be a first or second mod. $125 used.
Mac Flowpath Catback: I forget the name of the company I bought it from. Anyway, it has the Dura-Black coating (as long as it doesn't scrape on anything). Fit was good, but not great. Weld's were nice, everything bolted up smooth. The tails and tips are OUT-STANDING! This catback gives your 'Stang a mean snarl no matter what mid-pipe you are running. $320.
Diablosport Predator: Bought it used for $160 and its worth EVERY SINGLE PENNY. I used to to calibrate my gears, check trouble codes, shut of my exhaust-related CEL, and to tune my car. I gained 6.9 rwhp and 13 lb ft over the canned Diablo tune just by adjusting my fuel/spark curves in two dyno runs.
Harris Speedworks 2v Plate Nitrous Kit: Worth EVERY single penny. Came with 75-150 jets, arrived quickly with everything needed in a carefully packed box. The system is very easy to set up, and very effective. If you are considering nitrous oxide, I HIGHLY suggest checking out HSW's plate kit. I got mine for $416 shipped on Black Friday of last year. The car is stupid fun on a 100 shot, and the only thing I did for tuning was back timing down and add fuel with my Diablosport. So far so good.
Suspension:
Roush Racing Springs: Very good quality, easy install. They dropped the car modestly, but not too much. I am able to get a very good alignment without caster/
camber plates. They are pretty stiff and offer very little weight transfer when drag racing, but their ability to keep flat in the corners makes up for it. I paid $160 through a freind of mine.
J&M Adjustable Street Lower Control Arms: Got these as StangSuspension was going out of business. They looked and still seem to be very well constructed, although it's a 3-piece welded design. Installation was a bit tricky trying to get the bushings pressed in without popping out (because of air trapped between the bushings and pivot ball in the control arm), but aside from that it was smooth. Height adjustments are easy, but I need to re-grease the jacking bolts as they are getting hard to turn now. Paid $149.
Brakes:
Summit Racing Cross Drilled & Slotted Rotors: Bought these shortly after they came out. Everyone warned me not to get cross drilled and slotted because they are prone to crack after a little while. Almost 1 year later and alot of hard driving, and one REALLY abusive trip to an oval track (I overheated them to the point they were smoking and I lost almost all pedal feel) and they have not warped, cracked, or had any problems thus far. They are very high quality, I paid $60/rotor for the front end only.
EBC Greenstuff Pads: These work great in wet or dry conditions. They are an organic pad and give off alot less dust than a metal pad, and what dust is produced comes right off. Once they get warmed up a little they bite really well. Pad wear has been great so far at almost a year. $75 for the front's, purchased through Summit Racing.
I think thats all I have worth posting about. I hope that helped somebody out...
