Took the T5 out to get it freshened up and decided to pull the bell housing, clutch and flywheel to chase a small oil leak and to just look the clutch components over being the car was torn down this far already.
So the T5 needed 2nd gear and the 1/2 slider and the 3/4 slider was a little suspect to that got put in new as well along with a new input shaft bearing retainer, shift rail lugs, and a new reverse brake cone being I snapped the tab of the one in the trans a few years back. Also ended up replacing the shift rail due to the roller on the fifth/reverse lever pin/roller assembly having two big flat spots and sloppy loose on the pin. My buddy has about 20 T5's in a connex that are in various stages of broken that he robs parts off of and we found a really good shift rail so that got cleaned up and installed. Got the master rebuild kit from Hanlon and it was mostly complete due to my dumbassery, I failed to read where you need to call them if you want the brass synchro for reverse. Mine was still in good shape so we just reused it.
Anyhow, pulled the bell housing, clutch assembly and the flywheel fully expecting the small oil leak to be the rear main. No oil in the bell housing but it was on the back of the bell housing spacer plate. Found the leak to be the passenger valve cover which I am hoping that by tightening the nuts on the studs (yes my valve covers are studded) the leak will stop as I have the blue Fel-Pro performance gaskets and the back two nuts were a couple turns loose.
Cleaned up the plate and bell housing at the car wash with oven cleaner and a brush. Got back to the house and removed the pivot ball stud and inspected it and the surface on the clutch fork that the release bearing contacts. I ordered new parts and have them on hand and they are going in. The pivot ball is roached and the clutch fork has some significant wear. The ball stud is original to the '93 bell housing and I cannot remember where I sourced the clutch fork.
Pivot Ball Wear:
Clutch Fork Wear:
Waiting on the clutch fork to get here which should be Wednesday. I also emailed RAM Clutches tech support to see what the facing thickness is new and what the minimum thickness is before it needs to be replaced. The flywheel side looks to be thin but I have no idea what it was new as its been a few years since it was installed. My guess is I am going to be ordering a new clutch set and having the flywheel resurfaced.
Anyhow, just thought I would post up the wear on the pivot ball stud and the clutch fork so if folks didn't know or think about it they do wear. Both of which will add to a poor shifting experience with the T5 according to what I have read.
Pivot Ball Wear:
Clutch Fork Wear:
