The 4.6 Track Times Thread
I am new to the forum but here is my best time slip with my 99 Cobra DOHC 4.6
Mods: T56, 4.56 gears, NX 150 shot, Tubular front end, Coil Overs up front, aluminum flywheel and drive shaft, Raxle Axles, ported upper intake, JLT CAI, LT Headers and Magnaflow exhaust...
RT .813
60' 1.714
330 5.052
1/8 7.747
1/8 MPH 91.95
1000 10.016
1/4 11.932
1/4 MPH 118.06
Most definitely not a hit and run... This was at Firebird a few years ago. Going next Friday to try again.
Well went Friday May 27th Not a lot of difference in the time slip except it was going lean on the long end from a faulty fuel pump so mph was down and it fried a plug. New pump on the way, new plugs and compression check done :)
R/T .716
60' 1.602
330 4.898
1/8 7.625
mph 90.21
1000 9.967
ET 11.953
MPH 113.46
Reactions: 1 user
Year/Model: 03 GT UPDATE 11/22/22
Mods: 03 sb 2v 5spd: MMR 4.75 stroker,68/70 precision turbo, CMS stage 2 Turbo cams 3.73s, cold air, BBK throttle plenum,, sct software, upper and lower control arms. 4r70w w/ circle D converter SVE Drag stars, 95 style cobra r hood. Lethal Return fuel system w/ Twin 255s
FI: Turbo
60 foot: 2.185 (LOL)
1/4 ET and MPH: 10.59 @ 141.2mph
Tulsa Raceway
that's me in lane 2
1998 cobra, vortech s-trim, shm shortblock, forged rods, worked heads, studs, and stuff...
Reactions: 1 user
FYI I think you should add sea level of the track to the list. Will make it easier to compare
Year/Model:2003 GT Coupe
Mods: BBK 78mm Throttle Intake, BBK TL Shorties, SLP Catted X and SLP LM1 Catback, Street tires (17x10.5 Nitto 555 Non-DR), UPR Tubular front end and Coil Overs, MGW Orange handle, FRPP Drive Shaft, Spec Stage 2 w/ Stock fly, 3.73's, RSD
FI, NO2 or NA: Novi 1200 SL (Mongoose kit from MPH) made 360/360 of 5-6#s, Haven't dyno'd yet making 8-9#s, Stock internals
60 foot: 2.0681
1/8 ET and MPH: 8.5725 @ 87.30
1/4 ET and MPH: 13.1483 @ 108.65
Track Recorded at: Santa Pod Raceway, Poddington United Kingdom. 315' above Sea Level
What made you do BBK shorties instead of long tube headers?? I have a 2004 SN95, and I think I wanna do shorties
2000 GT
Bolt on's with drag radials
Way back in 2003 at Gainesville, FL
60' - 1.815
1/8 - 8.468s @ 80.8mph
1/4 - 13.3s @ 101.68mph
Reactions: 1 user
