Please read description before contacting me. I am in NO way at all intrested in parting this car out. The car will be sold as is, what you see in the pic is what you get. The car is a 2001 Ford Mustang GT Bullitt #03957 DHG. The car was involved in a single vehicle accident (both air bags deployed). The car has 64k miles on it and the engine has 65k miles on it. The engine is swapped it has a 98 spec 4v SVT Cobra motor with MMR IMRC deletes, 62mm BBK throttle body, JLT short ram intake, 90mm SVT Lighting MAF, Mach 1 modified fuel rail, Mach 1 COP’s, stock 24lbs cobra injectors, upgraded spark plugs, long tube headers, o/R X pipe, SLP Loudmouth catback exhaust. Stock transmission TR3650 with steeda short shifter. The rear diff has a B&M aluminum diff cover, motive 4.30 gears when installed i had new axle seals and bearing installed as well, less than 1k miles on them. The interior is 8/10 only damaged areas are the arm rest and both air bags, car has brand new Corbeau LG1 seats and brackets installed. Walbro 255 fuel pump, powerstop z26 warrior street brakes. Car has fully adjustable suspension all the way around, J&M weighted jacker lower control arms with adjustable height control, J&M solid non adjustable upper control arms, tokico blue shocks and struts, ebiach springs front and rear, with adjustable coilover in front and MMR caster camber kit. Wheels are 18x9.5 front and 18x10.5 rear Rovo Durbans in gunmetal. Tires are 95% good 295/35/18 Toyo Proxy 4’s up front, 315/35/18 Toyo TQ’s in the rear. Car will also come with SCT Bama Bullydog tunner already married to vehicle. Car has many other parts im sure im forgetting, please feel free to inquire. Asking price for entire car as is $3500 Vehicle is located in Victorville, CA buyer will be responsible for pick up.
