- Feb 17, 2010
- 4
- 1
- 13
Selling my 2000 GT. Car is located in Kent Ohio. Motor was just put together about 1700 miles ago by Victory Engines and CRT performance in Norwalk about 1 1/2 years ago. Just put 6 speed in the car asking $21,500. I can be reached at 330-815-9719.
MOTOR
- Teksid block .020over
- Forged cobra crank
- Forged manley rods
- Forged wiesco pisotons stock dish
- Clevite tricoat bearings
- Mmr billet oil pump & gears
- Every bolt that can be ARP 2000 is
- Mmr 7 qt oil pan
- Patriot performance stage 3 ported heads went over again at Victory Engines
- Todd Warren custom Turbo cams built just for this motor setup
- All parts in heads to spin above 7k rpm
- Trick flow valve covers (powder coated to match car)
- Front timing cover 3 bolt (powder coated polished)
- Edelbrock victor intake and elbow
- Accufab 90mm tb
- 1” spacer on intake to clear fuel rails
- POWER ADDER
- Hellion hot side
- 78mm turbonetics turbo ball bearings
- Custom down pipe 3” stainless from Steves automotive service
- Borla s type cat back
- Treadstone intercooler
- Turbonetics Godzilla blow off valve
- Tubronetics waste gate
- In cabin boost controller
- FUEL
- Sumped 04 Cobra Tank (bought from on3)
- Aeromotive Eliminator Fuel pump
- -10 sump to pre filter
- Aeromotive pre-post filters
- -8 post filter to aeromotive Y block
- Edelbrock fuel rails
- Aeromotive fuel pressure regulater
- -6 return line
- All lines AN braided lines all Russell and Frangoli fittings
- Siemens deka 80lb/hr injectors
- Pro M mass air meter (blow through)
- TRANSMISSION
- T-56 out of 03 cobra 17000 miles
- Trans gone through by shop
- 10spline input 31 spline output
- Mcloud RXT twin disc clutch
- Fidanza aluminum flywheel
- Strange hardened steel transmission yoke
- Custom dennys driveshaft 1350 nitrous ready
- All U-Joints upgraded to 1350
- Pro 5.0 shifter
- Steeda adjustable clutch cable
- REAR END
- Ford 31 spline posi unit
- Moser 31 spline axels
- Aluminum diff cover with pre load bearing bolts
- SUSPENSION
- Qa1 adjustable front coilovers
- Qa1 175lb springs
- Granatelli tubular K member
- Granatelli tubular A arms
- Eibach sway bar
- Sub frame connectors
- Torque box reinforcement plates
- Boxed upper and lower control arms
- Eibach rear sway bar
- All polyurethane bushings
- Qa1 double adjustable shocks
- Eibach pro kit springs
- EXTERIOR
- 18X9 FR 500 chrome wheels 275/35/18
- 18x10 FR 500 chrome wheels 305/35/18 Mickey Thompson ET streets
- 03-04 cobra front bumper
- 2000 Cobra R hood
- INTERIOR
- Autometer dash gauges
- Autometer digital oil, fuel pressure, water temp
- Autometer Monster tach with shift light
- Autometer boost/vac gauge
- Autometer wide band gauge
- Pioneer Avic N-2 DVD navigation head unit
