I am looking at buying a tuner and cai combo kit and trying to see which tune will be best as far as most efficient and which produces the most power. Any opinions or input would be greatly appreciated.
It is not clear that you and fomoco both understand what you want to buy. Maybe your expectations align better with a GT500. If a tune and cai blow your motor someone did not understand the design limitations of the engine. 400 na hp from 302 CID is rather efficient, IMO. I hope you find a Mustang that meets your expectations.If an intake and tune blow my motor I'm looking to buy the wrong car
Actually scratch that last comment, tj @ steeda cleared everything up about what I needed to know.
When i worked at dealers it was primarily the dealers call. In a #8 failure situation unless ford comes down and checks for the codes themselves then its ultimately the service writers decisionIf your engine blows and exhibits symptoms spelled out in that TSB I posted above, you'll be worried then! When it comes to warranty issue like that, you'll probably find yourself in a situation like this guy: Blown up 2011 5.0
It's been my experience it doesn't matter if your friends with the dealer or not. They don't have much control over warranty. You'll wish you were friends with the Ford zone representative instead!
Good luck!
Bama, they have a warrenty for you if your engine blows and ford will not cover it. They will. I dont think steeda has this.
Use google. They cover the #8 cylinder. That's why I chose them.Is there a Bama rep that can confirm this?
Good luck!
+1It is not clear that you and fomoco both understand what you want to buy. Maybe your expectations align better with a GT500. If a tune and cai blow your motor someone did not understand the design limitations of the engine. 400 na hp from 302 CID is rather efficient, IMO. I hope you find a Mustang that meets your expectations.
Scary.When i worked at dealers it was primarily the dealers call. In a #8 failure situation unless ford comes down and checks for the codes themselves then its ultimately the service writers decision
