Grabbin' Asphalt
5 Year Member
Whats the cc's on the 'X' heads?? ...You probably need more timing for the combustion chamber and a 75mm maf also.
I am betting my tacos on this oneEcam with stock gears sux, ...ask me how I know
I meant to touch on this too if they are the 64 cc version they may keep it right at stock comp ratio if not drop it which without boost or more timing its not helping the situation eitherWhats the cc's on the 'X' heads?? ...You probably need more timing for the combustion chamber and a 75mm maf also.
I meant to touch on this too if they are the 64 cc version they may keep it right at stock if not drop it which without boost or more timing its not helping the situation either
So i am still not straight does the car have stock rear end gears??? if so at minium 3.55 i would choose a 3.73 esp with the aod. and that car will feel light years better.ok cool
3.73 ASAP . put a little moreit currently has stock gears
has nothing to do with your TRANS it will shift and behave as it does now . the rear gear will get you intoquestion....how will those 3.73 gears work with my full valve body shift kit??
