Build Thread Want To Blow 5 Years And $50k On A Foxbody? Step By Step Instructions Inside!
I couldnt find zoop seal on-line, did find this and it features Groverdill's rims
http://www.svtperformance.com/forums/showthread.php?750729-Zoop-Seal-is-no-more
If it works I need some for my spun Aluminum rims I have on one of the cars.
Thanks for the post Mike
No problem.
Damn. Zoop Seal went out of business 3 years ago? LOL shows you how long its been since I bought that stuff. Honestly, I first bought it at a Turkey Rod Run in 2000 and it lasted me about 10 years or so as you use very little. I'm going to need to buy some more as it gets old polishing all the bling every month or so. Think I'll get the master kit .
Thanks for the link.
No updates to report right now. I told the engine builder to wait until after the holidays. I'm not in a rush to have it back. I am going to start working on the interior hatch area again. I'd like to get that finished up. And yes, I'm very excited to have it for the spring. I didn't get to enjoy it nearly enough this year!
I heard from the engine builder today. Good news and bad news. The good news is that the rod bearings and cam bearings are okay. The bad news is that the pistons are not. There are signs of excessive heat and metal transfer on the skirts. He does not recommended re-using them, so I'll need to order a set of 0.040 Probe pistons. Eff. The crank bearings will also be replaced.
The slightly larger pistons weigh 2 grams more than the existing ones. My builder said that should not be enough of a difference to require getting the rotating assembly balanced again. A slight over-balance won't hurt anything. He's going to send me some pictures of the parts.
Things could definitely be worse. I'll be ordering the parts and he'll get everything done as soon as he gets the parts. Hopefully it will be back together in a few weeks.
Apparently the cylinder walls were washed down so bad that there was literally no oil on the walls anymore causing metal-to-metal contact between the skirt and cylinder wall. That created too much heat and caused enough damage to the pistons to make reusing them questionable. He said I could possibly get away with using them if I really wanted to, but he's confident I would have issues down the road. The fuel content in the oil also contributed to the scuffing on the crank bearings. I never imagined washing the walls down for a few minutes would wreak so much havoc. Hard lesson learned from all this!
Reactions: 1 users
Here's the damage. Not pretty at all. The stock 100k mile pistons I took out of the original engine looked better than these. 100 miles and 8 pulls on them. They will make very nice ash trays. Too bad I don't smoke.
Stock 100k mile piston for comparison.
I did not, Nick. Mainly just because I found a reputable builder closer to me. Gil's son was very nice when I spoke to him on the phone though. Both builder's quotes were within $100 of each other.
I have a set of lightly used pistons if you need them for your update. Only 100 miles on them! I'll cut ya a deal.
It's always good to know when pricing is in line when it comes to this stuff, good info there. As far as the pistons go, I don't smoke either not to mention they are about .100" too small :D
WOWZERS... just spent the last several hours reading your build thread from start until now... Sorry to hear about the motor, that blows... You have inspired me as im sure many others to rebuild our Foxes... Cant wait to see this thing back together and completed!
That sucks an AMAZING amount of donkydik. Great pics of what can happen though for the next, "Can I drive my car un-tuned to the dyno"????
Edit: I know this this not your case Race. I'm just recalling all of the times that the question has been asked.
Reactions: 1 users
Thanks man! Glad you enjoyed the really, really long read.
That's the truth. Even though these cars are fuel injected, it's still possible to screw things up royally. My damage was done in a matter of minutes idling in my garage.
any reason you arent opening up the bore even more?
1. Money
2. Because streetcar
Going with substantially larger pistons would require a re-balance of the rotating assembly. It will also require more machining work. This ordeal is costing me almost $2k to fix, so I'm not interested in spending a dollar more than I need to now. The car will also make over 800hp to the wheels next time out. That was my original power goal, so I'll be happy with that! Also, knowing me, I won't be happy with a 347-363 engine that has 185cc heads, so I would be tempted to get a new set. I don't want to be tempted to do something like that. My little 331 (now a 333!) is perfectly fine.
Reactions: 2 users
The pistons were on backorder from Probe. My builder finally got them. Probe changed the valve relief design a bit. The original pistons were a made at least 6 years ago. It should not be an issue, but I'll definitely need to check valve clearance. New piston on right.
He is going to confirm the piston weights and then put everything together. It may be ready to pick up this weekend.
