So i'm converting to 5 lug using 99-04 PBR fronts and 94-04 rear set up. I am using manual brakes it is just a aluminum plate that bolts to the fire wall it appears to use factory pedal pin location. Any one have a suggestion on the appropriate master cylinder? Using @Mustang5L5 chart to have the ratio between 13-17:1, the 15/16 cobra would be 19.07:1, the 1" cobra would be 16.74:1, 1 1/16" would be 14.84:1.
I have looked for someone using similar set up but could not find anything.
Any thoughts are appreciated!
Scott
Scott
