Need some help. Long time stang owner and been wrenching on them (mainly Fox body versions) for nearly 25 years. Heck, I joined this forum 11 years ago although have not been very active. I know my way around cars but my latest project is just taking forever. Having a family pulling me in different directions doesn't help, but this is insane. It's been several years in the making and just beyond frustrating at this point.
It's a 93 Cobra with twin turbo built 347 and 5 speed and of course MS ECU. Specifically, I bought the MegaSquirt-II V3.57 plug and play and have full version of Tuner Studio and Mega Log Viewer installed on my laptop. I have been working with someone experienced with MS remotely over the past few years, but just seem to be having the same issue no matter what we do. I mean, I've literally done just about everything imaginable to this car to figure it out and it continues to run poorly. By that I mean, it lays over under load, misses and will not build boost at all. It starts up and idles steady aside from some slight miss here and there. Idle fuel pressure is around 42 psi. Off the top of my head, this is what I've been through...
* Engine was freshly built before install (has minimal test miles on it perhaps 10-20 miles at most over the last few years)
* Thought I washed the rings out after a number of attempted starts before determining fuel constant was way off for my injectors (I honestly thought that was pre-set in the tune since I gave them my injector size- thinking back to my days of running an AFM PMS, doh)
* Have since verified I have consistent cranking compression (120-130psi warm which seems lower than I'd expect but all cylinders are extremely close to one another) and low (<5%) leakdown
* Thought maybe cam was retarded (FTI custom ground for my setup), but verified it's correctly installed straight up
* Correctly set crank timing using piston stop (was off a few degrees initially)
* Replaced spark plug wires (Livewires) although even though they're new if they lay too close to exhaust, they will arc (I've had to tie strap them away from the manifold)
* Replaced spark plugs (3-4 times now)
* Car has historically run rich since initial tune, but is much improved in latest tune
* Calibrated Wideband (twice)
* Smoke tested and boost leak tested entire induction path multiple times (there are no leaks)
* Turbos are clearly moving air - you can hear excess air being vented through the intakes at idle
* Turbos definitely spool up - I can hear boost venting when throttle slams shut
* Blow off valve is not leaking - I removed it temporarily to verify
* Wired wastegates shut just to verify they were not opening for some reason and dumping boost
* I have a
Magnaflow catted X-pipe. I watched vacuum stay steady while free revving the engine around 2000 rpm to verify they are not clogged
* There is no PCV system on the car - PCV hole at rear of intake is plugged and I have two catches cans with a -12 line from each valve cover to each can
* There's no MAF of course as it's a speed density setup
I run 93 octane, no methanol.
I will say that I am happy to transfer some funds to anyone who can help me get this car running well. I have far too much time and energy invested in this setup to push it off a cliff... but let me tell you, it's tempting!
Latest tune and log are attached.
Thanks in advance.
