Electrical Stalling....Vss signal check?
Kid wita 5oh
I'm definitely not in the original hole
1,285
94
68
Saugus, MA
Working on a 89 with a 92ish harness & A9L ( Was put together with a newer harness not positive on the year)
306 w/ Edelbrock heads, cobra intake, E cam, pro-m with stock injectors, base timing at 14*
Having a stalling issue when coming to a stop with AC on, and/or slow speed turning. Then will have a hard time staying running for a few tries after stall, unless I give it throttle.
Have done the entire surging idle check list, fixed a few vac leaks and did base idle reset(a few times). Replaced the TPS and IAC (and swapped known good IAC from my car), and swapped in a stock MAF (and tried various clocking positions) all with no change. Voltage was right at . 9-1v at idle with either MAF and all positions
Car will idle at 850, then drops 100-150 rpm with AC on but stays steady
What type of signal/voltage should be output from the Vss?
and what voltage should I see across the IAC circuit ? Seeing between 3-4v at idle (more makes idle go up, right ? )
Have a BOB hooked up so I can test easily while running
I haven't opened the computer to check caps yet. Are these symptoms something that could be caused by that?
Open to any ideas
Thanks
I fought those issues for years before giving up and getting a tune. Some cars run perfectly fine without one but mine didn’t. The tune modified the dashpot settings so the anti-stall would stay active for a few seconds after coming to a stop. In other words my RPMs hang at 850-900 until my car completely stops for 1-2 seconds then it drops to 650. I also add 100 RPM to the base idle when the AC is on. There are power steering compensator settings too but I’m not familiar with them. Those settings have been a game changer for me. I have a A9L with a Quarterhorse running on a custom tune from EFI dyno tuning based on A9LV2 and it was worth every cent.
Just opened the computer. 2 caps are blown, with some board corrosion. ...
Off too ecu exchange it goes
Sounds like once you get your ECM overhauled it should run real good, those caps look bad just like on my 91, is there a website or article or anyone that knows what every component in these ECMs does and what functions they are responsible for? I would love to see something like that.
Yeah mine runs fine but it has this persistent minor idle issue and everything has been checked replaced and triple checked and I opened up my PCM and some of the yellow Chiclets have corrosion plus the capacitors look bad so that's my next step, might do it beginning of the year .
UPDATE
Installed the repaired computer. Did a base idle reset.
Idles great at about 775-800. When I turn the AC on the rpms still drop, but it idles steady.(I feel like the IAC should be bumping it up, no?)
On the test drive everything was great until I turned the AC on. Now it stalls as soon as it's taken out of gear to coast, using the clutch or not.( It's fine during a shift though)
The rpms just drop straight past idle and stalls(I can catch it with the pedal but have to stay on the pedal or turn the AC off
Ideas?
EDIT... this is at ANY speed, not just coming to a stop
I’d open the idle set screw just a tad. Still set it for a very low idle so the IAC is maintaining proper idle, but just lift it a little above the almost wants to stall rpm.
Pulled codes
96 c - fuel pump secondary circuit fault (I don't think this has anything thing to do with the issue)
91 c. - O2 sensor signal put of range
@Mustang5L5 I think I found an issue . . Does this O2 harness look wrong to you? tryin to compare to your write up but want to be sure
I bumped the idle up about 50-75 rpm and did another reset, no change in the issue
So just something to add(doesn't help at all just an observation). I unplugged the compressor and took it for a ride, no stalling with the AC commanded on.
So what's causing the computer to not catch the idle with the compressor engaged ?
