oil pressure
Gandalf79
24
Hey I just checked my oil pressure on my 79 fox and when it started cold it was hovering around 46 to 48 and at warm idle, it was at a consistent 22-24. Now I had to test this using an external oil pressure test kit that seemed to do the job but I don't think I had it fully tightened on the block. Wondering if I had fully fastened the adaptor, if the pressure would go up a bit from that22-24 line. I am reading that 20 psi is the minimum line of normal and I do not want to go below that.
I replaced oil sensor and the gauge didnt work but most of my gauges do not seem to be like the tach and oil gauges.
Just recently changed the oil with 10w-30 but I may change it again to hopefully get rid of any sediment in there.
Reinstall the mechanical oil pressure gauge with enough plastic line to get the gauge where you can see it. Run the motor and report back.
Okay I will do that this weekend. I am going to get it tightened on nicely to the block and fire it up again. and get back to you. Thank you.
Hoping I don't need to dive deeper into the issue aside from figuring out why the gauge isn't reading. Maybe need a new harness from the sensor to the cluster? Where is the tach reading from? Forgive my ignorance, I am learning as I go on this car. I am also looking for a diagram of the vacuum line for this car.
You might find this manual to be helpful...
Digital copy
Hard copy
  • Useful
Reactions: 2 users
Ok I’m so I was able to get the oil pressure test gauge tight and fired the car up and I started around 48 psi at cold start and it was there for awhile then as it got to hot idle it didn’t go below 20 psi
See videos
Had a question on a hose line that seems to be coming off a port right next to the pcv valve but it’s not connected to anything at the other end
Included a photo as best as I could get it
Last one was a video but it wouldn’t let me attach the file so I took a screenshot right after starting the car
