HELP!!! WTB or TRADE?
I have a 1967 tilt steering column that I'm going to install in my car. The problem is that at some time the upper collar was changed to a '68 version. I want to maintain my original wood wheel which causes the problem. The '67 version (which I need) has a rolled over edge at the top and a triangular hole at the turn signal lever. The '68 version (which I have) has a sharp edge at the top and a access door at the turn signal lever. When the steering wheel is installed there is about a 1/4" gap all the way around for all to see the wiring in the column. It would be great as well if it had the emergency flasher bezel on it.
Can you help? Can you advise where I might try if you can't? Many thanx.
Regards,
Andy
Regards,
Andy
