There's a 3 Valve with 555 Tranny 48k miles $1200 on Facebook marketplace. Not my cup o tea, but $1200 seems a screaming deal.
It's the leaks that bug me the most about it. There has always been a rear oil leak that drips out of the bellhousing..I think it's coming from the head gasket at the rear but I just don't know. Once I start leaning on this thing, like I did last time this engine had this intake on it that leak will become more pronounced, and it'll leave a pretty serious puddle on the floor.
Hell,..that's some of the best input I've gotten here..id be pissed if I went through all of this just to turn around, look under the car and see a puddle upon the floor.I've re-sealed my engine a couple of times... the leaks come back. I wanna try one of those rear main sleeves.
Yeah, I know some guys don't have the issue. I don't recall having any leaks when my car had a mild n/a engine. I didn't have any leaks for the break-in period. I get leaks when I start hammering it. So, my theory is that when you get to a certain level of torque/power, you put enough pressure on the rear main that it will open it up and start to leak. Or, maybe I just can't do that job right... definitely also possible. It's not leaking enough to cause any mechanical concern. It just amounts to drips of oil staining the garage floor. Guess I'll have to paint it. I can live with it in the big picture.
12psi with total seal gapless rings... zero blowby that I could tell.
True, and I expect that larger ring gaps for boosted cars also contribute to more blow-by.
However, most aggressively boosted turbo cars, like mine, are well-vented to atmosphere to prevent crank case pressure. I have the valve covers vented through a catch can, and the PCV system is dumped.
PCV could theoretically be routed to the down pipe and use the venturi effect to provide a vacuum. That only works on cars with very free flowing exhaust, straight through style mufflers at the worst, that won't build back pressure after the turbo, though.
If this is done right, there shouldn't be enough pressure on the low end to compromise the seals.
That I could tell... means nothing showing up in my catch can unlike my last build. I completely understand the concept of crankcase pressures.There is no such thing as zero blowby in any IC engine. There is always some pressure escape past the rings.
Very true.
This is why I stated "all other things being equal". Very true, you can help to reduce the amount of crankcase pressure with proper venting but you are still limited to what pressure you are able to alleviate based on the block design. SBF's were never designed to evacuate the crankcase pressures as quickly and effectively as needed with the power some of us make with them. Look at the large bay to bay breathing channels and chimneys that are cast into a coyote block to help relieve these pressures (as well as the other benefits from these provisions). You also have crankcase pressure generated by windage and the cylinder pulses contained in the crankcase that can cause pressurized leaks. I'm not saying this is the only cause, but it does contribute to the leaks we tend to see if higher horsepower/boosted SBF's
Pushrods RichieP » Wed Oct 15, 2008 8:01 am
Has anyone thought of trying carbon fibre pushrods? I was clearing my garage out at the weekend and found a set I'd bought for a (long since scrapped) MG Metro, and got to thinking about modding them to fit my B25SS. I know in reality there's probably not much weight advantage, although they are allegedly less prone to flex at high rpm, but I do remember them being significantly quieter when running in a clattery A-series.
Thoughts/experiences?
Cheers
Richie
Months ago I posted and said that the use of a P&G valve gapper would probably fix your sewing machine engine noise.
I had a home made version and it worked very well. It made an amazing improvement in an 1800 CC MG-B; it was like a shot of NO2 when the engine hit 3500 RPM..
You may find one on eBay or a swap meet, but even if you didn't, a home brew version isn't that difficult to make. A cheap dial indicator, some 1/4" aluminum plate and a 2"x2"x1" chunk of aluminum block are the main components.
Here's how it works:
View: https://www.youtube.com/watch?v=5NPM185P33w
