Car is located in nashville, Tn. Around 2,500 miles on 347 stroker , trickflow
heads, comp cam , bbk upper & lower intakes, 70mm bbk throttle body,new
injectors,adjustable fuel pressure regulator,New msd ignition and coil, accel
distributor, bbk headers, newer exhaust , New 240 amp alternator & 4ga. power
wire. Tremec 5 speed maual trans with around 2,500 miles as well and short
throw shifter. Cold a/c and hot heat, pretty clean car. Dyno tuned by delk
performance, 345 whp & 385wt. check engine light out now an have dyno sheets.
About 123,000 mi. on body , paint isn't bad, poly urethane bushings, hotchkis
performance struts an gas adjutables on rear. bbk body connectors, traction
bars, and 3:55 rear end gear. Low coolant light comes on because overflow
bottle is cracked an it has the sensor on top. NO TRADES, NO paypal, NO
personal checks $7000.00 OBO (615-924-5279) Leave msg. an I will get back to
you a.s.a.p. It can be seen on ebay, item # 181675772627 MAKE OFFER THANKS!
