I have a 1991 Mustang LX Coupe for sale only. The car is highly modified by the previous owner. Its an original V8 car that had a short block 302 in it when I bought it. The motor has been completely and professionally rebuilt back to mostly stock, It wasn't entirely necessary. On a cold morning the oil pump shaft broke which damaged the crank and bearings. I had every bearing replaced, honed and put new standard sized rings in, went on and did a valve job with all new keepers for reliabilities sake. It has a built AOD with 4r70w gears in it with a "900hp" torque converter. It shift strong, the linkage needs played with to get the kick down to work properly. The rear end under this car is a posi 3.73 with yukons. This car functions mechanically 100% properly, it just needs the little things. timing ad tuning, clear coat, gauges wired, door locks fixed, tie rod end, just little cheap stuff.. I will gladly talk about all the issues I know about with the car. I just sunk roughly $2k into the motor and I am in no way in need of the money so please no low balls. I have a clear title in hand and am located in fredrick, maryland.
Engine Modifications: GT40 Intake, GT40P Heads, Trick Flow stg 2 cam (I believe). All new internals from timing chain to freeze plugs.
Transmission: It was built by a transmission shop in SC good for "900hp", Only thing I know about it is that it has 4r70w gears and a beefy torque converter.
Interior: Terminator Cobra seats, new headliner, carpet, and rear seat delete kit. The dash has been replaced and the speedo and tac are not functioning properly.
There are a lot of other mods, (subframe connector, custom tower brace, eibach goodies). I just moved up here and do not have any place or any tools to fix any of these little issues.
Please message me or email me at [email protected] for more pics, videos, or any inquiries.
I really just need this thing gone. $6,000 obo. ONLY trades would be for sixty $100 bills, although I would consider three hundred $20 bills.
Here is a short video of the car idling:
View: https://www.youtube.com/watch?v=ZNYdtIeoLSo
VIN: 1FACP40E2MF178674
Vehicle Location: Frederick, Maryland. 21701
