1994 Mustang Gt Has alot of work done. Motor has less than 1000 miles on it. I'm just ready for something new. I have alot of time and $ invested.
List of things that I can remember:
-Car dynoed 486 rwhp have sheet mild tune
-331 roatating assembly CHP SrS Probe Pistons Forged
-DSS level 10 block
-DSS main support system
-clevite 77 bearings mains and rods THE BEST ONES YOU CAN BUY!
-Brand new FMS oil pump high volume
-Moroso 7 qt oil pan
-Anderson b31 Blower cam
-Harland Sharp 1.6 rr
-Trick Flow Alum. Heads
-Cometic Head Gaskets GOOD ONES!
-All ARP fasteners including head studs
-Trick Flow Track heat Intake
-1" plen. spacer
-Vortech Strim 8lbs
-Anderson Power Pipe
-Pmas MAF 80mm
-42lb FMS injectors
-Trick Flow intank 255 pump
-bbk inline boost pump
-MSD Pro Billtet Dristributor
-MSD 6al Ignition Box
-MSD TFI Coil
-Aeromotive Fuel press regulator
-3 core Alum radiator
-T5 trans TIGHT
-Spec stage 3 clutch grabs it ass off
-alum drive shaft
-AEM wideband 2 1/16
-AEM Fuel Pressure gauge 2 1/16
Auto Meter Phantom
-Water
-oil
-boost
-Indiglo indash gauges
-Anthracite fr500 rims 18x10 18x9
-Just put on not painted s351 wing
-Have cobra hood to also go along with
relocation for job forces sale. . I also have parts to go along with the car ex. meth injection, body parts etc..
8800.I will entertain offers, but not going to be low balled.
856-498-5941
-DSS level 10 block
-1" plen. spacer
-Vortech Strim 8lbs
-Pmas MAF 80mm
-42lb FMS injectors
-MSD TFI Coil
-T5 trans TIGHT
-alum drive shaft
Auto Meter Phantom
-Water
-oil
-boost
856-498-5941
