setup includes 1 paxton supercharger head sn-2000 fresh rebuild, less then 1000 miles, upgraded impeller to push out 7-9 psi and brand new pully.
crank shaft pully, Tensioner bracket with pully, back main bracket, which was cut to fit alternator better, front main bracket which is welded to fit your stock alternator, stock Tensioner and accessores bracket still mounted, belts, paxton fmu with hoses- set to 30 pound injectors. 2 belts, some of the Air hoses in the picture. and most or all of the bolts which are not pictured.
The only thing needed will be a outlet pipe, which goes from the supercharger to the throddle body.
call me at 631-872-4397 asking price is 1250.00 located on long island
i rather you call me then write on here because i dont come on here too much
