ENGINE
302- built july 07.
probe forged pistons
gt40 heads-stainless manley valves
cobra intake
e 303 cam
24 lb injectors
comp cams rocker arms
tfs pushrods
prothane motor mounts
76 mm maf
70 mm t/b
k&n
190lph pump
trans
original 5 spd in the car
king cobra clutch
hurst shifter
steeda cable
rearend
3.73 gears
detroit locker
31 spline axles
disc brake conversion
hpm adjustable upper and lower control arms
monroe shocks and struts
drilled and slotted rotors- ebc pads
cervinis stormin normin hood
eibach lowering springs
needs
roof paint is oxidized
rear bumper, original is torn. i have a replacement
will need front tires in about 3000 miles
motor uses no oil at all. always used 10-30 synthetic in it
car has 93252 original miles on it
302- built july 07.
cobra intake
e 303 cam
24 lb injectors
tfs pushrods
76 mm maf
70 mm t/b
k&n
190lph pump
trans
king cobra clutch
hurst shifter
steeda cable
rearend
3.73 gears
detroit locker
31 spline axles
needs
