- Jun 15, 2005
- 349
- 0
- 16
Ive got a 99-04 Vortech kit in great condition everything you need to get this running on your car minus the oil feed splitter which is a simple 1/4 NPT splitter that can be bought at napa for a few bucks. It includes the stock 3.6 inch pulley and produces 8 psi on a stock motor.
The head unit is a V1 that was rebuilt with V2 internals. The unit was fully rebuilt, seals, bearings, the works by Vortech about 10k miles ago.
The Kit includes:
Head Unit with 3.6 pulley
Bracket w/ idler pulley
Correct Size Belt for Vortech
Oil feed/return Line, Oil return L piece
36 lb Blue Top Injectors
90MM MAF Sensor
All piping for Unit
Hoses and Clamps
Nuts and Bolts to bolt the blower on
Vortech Chip
OEM Bypass setup
SCT 4 Bank Chip tuned for 04 GT and stock 3.33 pulley
vacuum line and t fitting for boost gauge hookup
Full Instructions
You can look at my pictures and see the kit is in very good condition and was taken care of.
I would recommend a new air filter also.
You will need to get an intank fuel pump upgrade most likely and also may need to get the car dynotuned and the SCT Chip reflashed. I will include the original Vortech Chip and the SCT 4 bank Reflashable chip. The tune was for a 04 gt with its only mods being high flow cats and some free flowing mufflers. You may be able to just pop the chip in and throw it on a dyno and get away with not retuning it if your car is similar.
$2500 OBO
The Kit includes:
90MM MAF Sensor
All piping for Unit
Hoses and Clamps
Vortech Chip
OEM Bypass setup
Full Instructions
$2500 OBO
