Okay so I was checking my pushrod length and valve clearance today and noticed my rockers werent riding in the middle of the valve stem. Both exhaust and intake rockers were running on the inside of the stem. It looks to me like the AFR rocker stud to valve stem centerline is off. Anyways the only way I see to fix it is with adjustable guide plates, problem is I have only found them for chevy's. Has anyone else had this problem or found a way to fix it? If you used adjustable plates are they supposed to be welded after you figure out the spacing? Please help!
