Hi guys,
I have the coyote crate engine. I am going to install it on a FFR MK4. the alternator is the coyote alternator (Ford Racing Coyote' 5.0L 4V Alternator Kit (11-12 GT) at AmericanMuscle.com - Discontinued) there is a plug on the alternator that gets connected to the coyote harness. the plug has three wires. on the alternator there is a scheme that i believe its for the wires (BVS, RC, LI). I was just speaking with Ford Racing parts tech line, and he said that in order to run an alternator light I have to connect one end of the light to the VBAT wire on the alternator and the other end to a ground. I asked about a resistor in between and his answer was " I have never did that before but he doesnt think I will need one (resistor). Also he said that I should not connect the other two pins (RC, IL) as the PCM will not use them and it might overcharge.... anybody did this? or know something about it??
Thanks
Hakeem
Thanks
Hakeem
