"...There are Other Disc Brakes out there that "Will Bolt on, "will work".
These Home made parts will not be here a few years from now, No way to replace, Fix the problems that may arise, and they, the "Company" won't be there. See This Many times over 30 years.
Quality-- Parts that have been time tested, Proven, Backed up, is another factor. Select Name Brand Products, it's a standard we all know is a necessary..."
As a supplier who produces "home made" brackets for disc brake conversions [which are actually components machined by a highly competent machine shop], the only thing I provide is the mounting means [the brackets] that connects the calipers to the rear end or onto the spindles. The rest of the parts are all late model Ford components, and all these brake components are definitely time tested/proven both on the street
and on the track.
Brake parts themselves wear out, but in 9 years of production, I have yet to have a customer tell me that the
mounting brackets they got from me have worn out. This is because the brackets are a non-wear item.
Whether or not, years down the road I'm still around, the brackets will still be working just fine on a customer's car and the SN95/Cobra Ford-produced brake parts that were hung on the brackets will still have replacement parts available to refurbish them with for many more years of service.
If the early Mustang disc brake components are still around more than 40 years after their original production, then I'm pretty certain the SN95 GT/Cobra brake parts will be too.
If one of the main selling points is that the stock, early Mustang K/H brakes are "bigger" than the Granada discs, then that is true. However, it isn't as good as it sounds when you actually measure the diameter difference between the two. Stock K/H rotors are 11.29" in diameter. A Granada rotor is 11.03" --a small difference of only .260" [just over 1/4"].
If we are going to use the "bigger" rotor diameter as a selling point, let's go with something that really is
bigger --A '94-'04 Cobra/'01 Bullitt/'03-'04 Mach 1 front rotor [used on the higher performance late model Mustangs and Corvettes]. It comes in at a whopping 13" in diameter --a full 1.61" larger than the K/H rotor.
The Cobra/Bullitt/Mach 1 twin-piston aluminum PBR caliper is also far lighter than the early, stock K/H cast-iron caliper and the Cobra caliper/13" rotor can be mounted to either an early Mustang drum or disc brake spindle, or on a Granada disc brake spindle. This gives lower unsprung weight of the car's front
suspension which improves handling. The main advantage though is it also has
far more stopping ability that the stock K/H setup can't come close to competing with.
If a person is looking for a stock setup, either of the factory K/H or Granada setups are good and nearly on par with each other. If someone is looking for a lot more braking ability, the Cobra conversion setup has the upper hand in that battle.
