I have a 95 mustang engine and trans in my 63 falcon. I have a egr eliminator installed in it but I have a code 558 for the egr solenoid circuit . This runs to pin 33 on the ECU. Question is what do I need to do with this circuit to trick ECU ?
Thanks for the info I was under the impression that if I didn’t fool the eec that the egr was there it would not run correctly. What your saying is other than a annoying CEL it is fine. I did pull all codes and that was the only one the I thought would turn light on . Other codes are smog pump related. Etc. question I have a egr delete plugged in where egr is supposed to go but on the egr solenoid circuit I didn’t do anything with pin 33 and that’s what I think is making cel come on. I was thinking if I did something with that circuit the eec would think it was fine and not trigger cel . Your saying leave it be and unhook light or have it tuned off.You don’t need to trick the EEC.
If you trick the EEC, it will continue to operate as if the EGR is still there and working properly, and then the EEC will pull fuel & add timing.
Having the CEL on because of an EGR code effectively disables the EGR functions. The EEC knows there is a problem and won’t use it.
If you don’t like the CEL, it can easily be turned off with a tune and the EEC will no longer look for it.
CEL = good
Trick = bad
FYI the EGR lowers combustion chamber temperatures and it’s only active at part throttle, so it doesn’t cost you any power.
CEL = good
Trick = bad
Thanks for the info. Only reason I ask about the ECC needing the EGR is that I read on several sites that without the ECC seeing a functioning EGR is will not run properly or run in open loop. I’m not set on tricking the ECC I just want car to run correctly.No Tricks.
Remove your “eliminator”.
Forget about pin 33.
Let the CEL be on.
You do NOT want the EEC to be using any of the EGR functions/ strategy.
The only ways to accomplish that is by having an EGR fault code (CEL) or having it turned off via a chip tune ($350-$500).
The chip tune will remove the CEL.
The EGR is NOT functioning properly if you delete it or any portion of it. Why would you want to trick the EEC into using those functions/ strategies???
