- Mar 30, 2005
- 4,749
- 95
- 134
As most of you know Ford assembly line employees use a lot of electrical tape under the hood. Some of it is on there really well and some of it comes loose. The Bullitt Archive says to use liquid tape to solve this problem:
http://www.bullittarchive.com/5008.htm
However, I chose to use blue zip ties to replace pieces of electrical tape that were coming loose in various places.
Here are some pics, also note the shrink wrap tubing I applied to the negative ground battery wire. That wire is directly behind the hood/headlight gap that allows engine ventilation and gets blasted with water and other corrosive substances when the car is travelling at speed.
