Balanced crank
Machinist stamped crank
Main bearing clearances
Moly assembly lube
Rear main in
Crank installed
Snap on clicker
Decked .002
Everything is balanced
rod caps with material removed
Pistons were removed from rods and individually balanced
Lucky #7 was the lightest piston
Material was removed from each end of the crank to finally balance entire rotating assembly with balancer and flywheel included
Rod bearing clearance
King race bearings instead of being beveled towards the crank side are cut narrower instead. Doesn't look right, but it is!
I torqued rod bolts with in/lb wrench - 240in/lb
Completed short block
Random work area
Moly assembly lube
Rear main in
Crank installed
Snap on clicker
Decked .002
Random work area
