Man that car handles so much nicer now. Those new struts really helped out alot. Glad we got it done man. Now get that mid pipe on!!
i think my rear axle is not centered. i think first up im gonna get my upper ca bushings done, then remove the lower iso from the front springs, then do a phb to get the axle right. then its full speed ahead on the cobra brakes. this summers going to consist of making as much money as possible. i need all that (1000 dollars or so) and a new laptop (charging port on mines going bad)
trucks almost where i want it for now. im starting to think of engine setups for the fox also.
any ideas? gt40x heads and tfs2 cam? trick flow top end kit? on3 performance turbo on the stock block?
once this car has the cobra brakes and a road and track box, what kinda motor /setup would you guys like to see in it?
you guys never fail. a build thread isnt cool till it has a ls9 or twin turboed 427 in it. typical
no really does this car look like it would be suited to a nasty HCI combo with possibility of spray, or does it look like it should have the stock motor with a small turbo pushin 10 pounds through it?
