Hello guys, I have a 2002 ford focus, 4 door. and I am trying to locate the Inertia switch, or the fuel cut off switch, I have had an idle problem, witch I am sure was due to a vacume leak, me being my lazy self I put if off and then today it died on me, so I popped the hood and sure enough the rubber hose for the PCV valve was caved in, so I walked to the parts place and got a new one, However the car didn't start, so I checked around and I am thinking it's not getting fuel. I couldn't find any check valves on the actual fuel rail, but I found what I believe to be some kind of relay of some sort for the fuel system on the passenger side near the firewall, it has fuel lines going into it, Couldn't actually see the word fuel on the line but they look like fuel lines to me, any ways there was one of those check valves on that, so I unscrewed the cap pressed down the needle and nothing came out, kept it pressed down while someone tried starting the car and still no fuel came out. so before I get into checking the fuel pump and all that I would like to know where the Intertia switch is, and then if I am wrong about what I believe to be part of the fuel system and it is in fact not part of the fuel system then where do I check to see if there is fuel going into the engine.
Thanks
Ford Kid
Thanks
Ford Kid
