Expired Fully Built 94 Mustang
fast5ooh
Fully built street/strip car up for sale!
Hey guys up for sale is my fully built mustang. Has everything possible except a cage.
ENGINE
383 stroker 9:1 compression
NEW AED 750 double pumper w/ mechanical secondaries
NEW Edelbrock Victor Jr manifold
NEW Edelbrock Victor Jr heads
Scorpion 1.6 roller rockers
New msd distributor
Probe inverted dome pistons
Eagle h beam rods
Forged eagle crank
Comp cams power adder cam
Engine is girdled
Shorty headers and brand new custom 2.5” aluminized exhaust w/ magnaflow exhaust to rear
Canton 7 quart pan
MSD digital 6 box
NOS nitrous plate with large solenoids up to 250 shot with purge
NEW Mishimoto aluminum radiator
TRANSMISSION
Performance automatic C4 super comp rated for 1000 HP
Fully rolerized & red alto clutches
Manual reverse valve body & trans brake
PTC 10” converter with 3800 stall
New tranny cooler with all steel braided lines
Hurst quarter stick shifter
Aluminum drive shaft
DIFFERENTIAL
Ford motorsports diff with carbon clutches
4.10 cryogenically treated gears
31 spline strange axles
Welded axle tubes and diff cover with girdle
SUSPENSION
90/10 lakewood struts
Strange adjustable rear shocks
Hotchkis upper & lower solid rear control arms
Moroso drag springs and rear airbag installed
Flaming River manual rack and pinion
Welded torque boxes & custom sub frame connectors
FUEL SYSTEM
Sumped tank with #8 steel braided lines and fuel return system
255 walboro out of tank pump
Aeromotive fuel filter
Aeromotive fuel pressure regulator and separate Holley regulator for nitrous system
Optima red top battery with battery relocated to the rear with on/off switch
Nitrous is fully installed and wired with purge and switches in car
Fuel pressure/oil pressure/RPM gauges all installed and functional with lights
Radio with Ipod adapter
Power windows, power locks, power seats, and power mirrors
ALL NEW TIRES on weld pro stars with extended wheel studs as required by track specs
Cobra front bumper and cobra R hood with LED fog lights
Times given to serious buyers. Perfect grudge street car and even competitive in fun ford weekend street car class
Runs between 190-200 in heat of day with no issues. Runs on 87 pump gas with no detonation with proper timing, turn on the bottle and run C16 without an issue when youre ready to race.
$8500 OBO.
If interested , message me or contact me at 786-478-1634, no late night calling please.
