Well, I did a whole top end and after getting it back together I couldnt get it started. After going over the much posted "No Start" list i FINALLY got it started.
So, heres what happened. I went over timing and the valve adjustment multiple times. Everything was done to a T. I Put it all back together and still nothing. It cranked but wouldnt start. I was getting seriously confused.
Anyway the most simple thing popped into my head. Compression????
So, I did the compression test and was getting 60 lb. readouts on all of the cyclinders. When I was bumping it over I had the fuel relay disconnected. What I figured was that the cyclinders must be washed out. So, I put a few drops of oil in each cylinder via the plug hole. I then put compressed air to each cylinder to see where the blow bye was. NONE!!!!
Put it back together and I had 100lb plus compression. Started it right up.
Now here is my question. The car wont stay running unless I hold the throttle around 1700 RPM. Think the timing is still a touch off or is the computer still trying to get used to the new hardware????
