I was going to meet some friends tonight. The total distance in which this stuff happened was less than two miles. When I left, I had the car idling for a minute or so before I left, and the car's RPMs dropped but then came back up. Once I left, I was going down a hill, and looked down and noticed that the engine had stopped. I restarted it and continued on my way. Just after that I was at a stop light, and the car had the same idling issues. I had to give it a little gas to keep it going.
I made it to my destination, but when I went to leave, the car wouldn't start. It cranks and cranks, but it doesn't pick up and go. Sometimes it will start but then dies soon after. It doesn't go for longer than a second.
I took of the negative terminal on the battery for a while, took off the IAC and cleaned it, and checked for tightness on my packs and plugs. I also checked the inertia switch and all fuses in the front distribution box and under the driver's side dash. All looked good.
After all of this I tried to start it up and same thing. On one try I got it to run choppy for about 20 seconds, but not long enough to think about getting it moving. Also, every time I move the key to the on position, I hear that humm or buzz which I think is the fuel pump.
The car is stuck somewhere I don't want it, and I am not sure what route to take. I am not 100% sure on the status of the fuel filter, I bet it needs to be replaced.
Can anyone help my stranded car?
