Head studs or bolts where to get them?
bmo37
2,368
New Jersey
I need some new head studs or bolts but it seems arp is a fricken ripoff charging over 100 dollars for the studs or bolts does anyone else know where i can get them or another brand for cheapier. I hate to spend more head studs/bolts than i did on my entire fellpro gasket set.
im not sure about strength wise between the studs and bolts, but you get more accurate torque readings with studs. i know most high high horsepower heads use studs. at least from what ive seen. :shrug:
the good thing about studs is that you can reuse them like 5 times...bolts, i believe, are not supposed to be re-used. My ARP's were around $100 I believe, but I didn't get them from summit, I got them from the local speed shop, which gets things around the same prices as summit - some cheaper, some higher
