Fox HELP PLEASE Surging idle and then Stalls
Luisr010
Miami, FL
need help my mustang is stalling.
It’s a 1987 ttop Mustang GT.
It starts and surges high for a second then low rpm bouncing until it dies.
So far what I’ve done:
Fuel pump, Fuel pump relay, Fuel tank, fuel filter,
Fuel pressure regulator, tfi module, egr valve.
Took off my intake to and inspected all the hoses.
I get 30 psi at the rail at the front.
I spray starter fluid after the maf a little bit and it
Evens out and runs nice. Then it stumbles and stalls again.
I’m all out of idea I need HELP please.
30 psi in what condition? Vacuum line off and plugged?
You should have 39-40psi. If only 30 you should investigate why it’s low.
Also, dump codes and perform vacuum leak/smoke test
