Info. request on aluminum heads
earleys94gt
1,223
Ashley, Ohio
To those of you running aluminum heads, and drive you car daily or more often then just on the weekends, I pose this question to you.
Have you had any issues, like overheating, blowing out spark plugs, leaks, head gaskets etc.
I am thinking about getting a new long block for my car, as all my piston rings are bad(compression below specs.) and depending on the money available I might get aluminum heads. However, I also need to keep somewhat of a budget as both the AODE and rear-end will need to modified as well.
All opinions/advice welcome/needed, thanks.
