Ive been kinda mad that i didnt get a vortec for the air-water cooler, or a ati procharger kit with and inter cooler.
I beleve there is still enough room to add and intercooler but the piping would have to be custom bent. My friend works with tubing and metals all the time and can help.
My first question is that I belive the vortech and novi 2000 can be rotated a pretty good amount which should give me the room i need to pipe in an inter cooler.
I have a 14PSI pully vs the 8lb that I have stock. I am also thinking of buying a blow through maf and a blow off valve instead of having the upgrade the bypass system with bigger hoses and the bypass itself. (but i like the sneeze valve!)
I am currently running a 4" power pipe to the blower which I should be able to keep. Then a 3" from the blower to the TB. I'll have to keep the 3" going to the inter cooler and 3" to the TB to get everything to fit.
So my question is, Has anyone done this before? or Does anyone no a place I can buy the pipe/intercooler/pipebender/couplinks I will need to complete this task.
Everything will be tuned by me once its completed.
