hi dudes
I'd like to dial in the injectors properly:
I installed 19 lb/hr aftermarket injectors in my mustang GTS 95 and realized afterwards that their flow rate was tested @43.5 psi, not @39 psi
So, @jozsefsz what are the REAL numbers?
39/43.5*19=17.03 lb/hr for high slope? (AHISL)
24.97 lb/hr for low slope? (ALOSL)
that's it?
So make sure your injectors are dialed in properly (remember that many aftermarket injectors are flow-rated at 43.5psi, not 39 that you're getting at the fuel rail, which makes them act smaller than their rated flow so you should put in the REAL number for high & low slope adjusted for fuel pressure). This small tip was a source of much frustration and makes a lot of folks think the computer's impossible to tune. It's not.
that's it?
