Willy0314
T3AL said:so is a 20 overbore good? bad? or just imbetween disaster?
buy a shop manual. A chiltons will tell you what the bore is suppose to be stock, and what all the over bores are supposed to be. It will tell you want the max bore is suppose to be also. The reason you want to bore over a block as little as possible, is because you want to have material left over for the next bore job. A hone is supposed to do nothing but remove glaze.
As far as Hypereutectic pistons go, they are a cast peice. When they are cast they are infused with a higher silicon content then normal. This provides a longer wear life, however not it high performace applications. Dont ever run them with any kind of power adder or high compression. You definatly need to buy a forged set. Especially since your gonna need a serious compresion ratio to make 200hp n/a
