Torque specs on clutch
mytight95
2,605
43
Dothan,Al
When i install my clutch today, what are the torque specs on the pressure plate are there any? a sequence would also be helpful otherwise i am just gonna do the star pattern thing
thanks guys,
jason
p.s. car should be back up and running with new tranny case driveshaft, new exhaust, and the whole nine yards flywheel back, by this evening.
wish me luck!!!!!
DOUBLE CHECK THIS as I'm going purely off memory here, but I believe the flywheel bolts are 80ftlbs and the pressure plate are only 20ftlbs.... BUT DOUBLE CHECK THAT. I know everytime I do it I think the pressure plate torque specs are pretty low. MAKE SURE YOU USE A CLUTCH ALIGNMENT TOOL!!! If you already have one, great, if not you must have one. Just torque the bolts in an alternating star pattern.
Thanks, yeah i got a clutch alignment tool with my clutch, i got a new king cobra clutch as mine was warped somehow, due to the driveline flex my car suffered when the driveshaft went
thanks
again
jason
