i bought a 95 gt with a spun bearing and replaced the motor with one i had in my 87. the car has a e cam,trick flow intake, 3.73,full exhaust, 65 mm t body.155 fuel pump and adj reg. heads are on the way! anyways the ran like a turd, so i clened the maf sensor(previous owner had installed a k&n) and was going to check and set the tps and when i went to check it one of the bolts looks like the head was ground off with a dremel or something and i noticed that the idle air control valve wires were bared liked they tried to adjust that instead of the tps. could this cause my car to run like a turd or is it more than likely something else? i know the tps is out of wack because it moves when i touch it. that will be fixed tom.
