I finally started my car up with the Trick Flow street heat H/C/I kit. It comes with the Twisted Wedge heads, stage 1 cam, and street heat intake. I'm also running 24lb injectors, 73mm C&L MAF, Kirban AFPR, stock throttle body, and 255lph fuel pump. When I first started the car, it barely idled, which I guess is normal for a new cam. After a little while it idled normal between 600-700rpms. I put the timing at 14, adjusted the TPS, and set the FP at 32psi. Then I drove it around. It was fine until I came to a complete stop at a red light, the car kept dying whenever I was stopped, which is strange cause it never did it when it was idleing in my driveway. I had to keep my foot on the throttle to keep it idleing. Then I stopped off at a parking lot, cranked the idle up to 800rpms, still died. I tried cranking it up to 1000rpms, but it would jump up to 1200rpms. It runs fine at 1200rpms, but that seems a little high to me. What do you think I should do? Thanks for any suggestions!
