you can use the spindles from a 67-69 mustang if you like, or even get a set from a 70-73 mustang though you might have to change the tie rod ends to use these.
Yeah, but since your shopping, you'll be better off with the original 64-66 V8 spindles, which have the exact correct steering arm angle and turn stop location.
I'm pretty sure I have a set lying around, without hubs though. they have the tie rod holes reamed out (correct taper) to fit Granada tie rod ends as well. Just need to find them if your interested.
If unisteer's tie rod ends are the same as stock then it probably won't work. The Granada ends have the same taper but a larger diameter, top & bottom. They won't even fit through the stock holes....
