My idle surges from time to time from 750-1100, but very infrequently. It seems completely random as far as I can tell. I pumped the brakes when it happened last and the idle settled at 1100 (even though my idle is normally set at 750) and as soon as I stopped pumping it surged again. I've heard if pumping the brakes stops the surge, it means there's a vacuum leak.
My questions are as follows:
1. Even though it happens at random, does this still mean a vacuum leak?
2. Does this mean that there is a leak in the brake system, or could it be anywhere?
3. I know about checking the hose that runs from the vacuum tree to the master cylinder, but what other hoses could be affected based on what I've told you?
Thanks again!
Thanks again!
