Hi all... new to site. Have an issue that no one can diagnose. Please help!!
Full PI swap on 97 block.
1st block- did not rebuild lower end, just put heads on.
2nd block-
I'm not an expert, but several at the scene and no one can figure it out. Thinking it is a head related issue? Too much pressure to valve train? But then why are the rods not getting oil?
Any ideas???
- Canton road race pan
- degreed cams
- Ford Racing high volume oil pump
- Windage tray
- admittedly went cheap!!
2nd block-
- block worked
- DSS balanced rods and pistons
- stock crank balanced and turned
- All clearances within tolerances (on the loose side)
- removed and inspected all valves
- removed oil/water cooler for standard neck
Any ideas???
