Wheel/Tire - Need your info for FAQ
Wheels:
Brand - America Racing (Shelby)
Model - Razors
Wheel Diameter - 20"
Offset - Not sure
Did you need/use a spacer? - No
Tires:
Brand - Pirelli
Model - P Zero
Size - 255/35/20
Suspension Mods - Eibach Pro Kit Springs, Tokico D-Spec Shock/Struts
Picture:
<a href="http://smg.photobucket.com/albums/v76/villains/Mustang/?action=view&current=2006MustangGT002.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v76/villains/Mustang/2006MustangGT002.jpg" border="0" alt="Photobucket"></a>
Wheels:
5 Zigen
Pro-Racer GN+
18x9.5"
+43mm
Did you need/use a spacer? I needed to use a 1/8" spacer on the front only because the S197 hubs are deeper than the recess in the wheels. They also required the hubcentric centering rings and special lug nuts that came packaged with the wheels.
Tires:
Cooper
Zeon 2XS
275/40-18
Suspension Mods: Tokico D-Spec shocks/struts, Vogtland springs, J&M LCA's, Spohn adjustable panhard bar, Stillen adjustable F&R stabilizer bars.
2007 must gt/cs
wheels
brand: OE
size : front 17x9 rear 17x10.5
type: bullitt
offset: normal
spacers? no
tires
front fierce 275/40/17
rear michelin pilot sport 335/35/17
no susp upgrade and plenty of room for these big boys
thinking of changing to kmc nova 20x8.5 and 20x10 chrome
with 255/35/20 and 315/35/20 veredstein tires if they will fit with no mods
wheels
brand: OE
type: bullitt
offset: normal
spacers? no
tires
:eek: got a pic with those showing clearances?
g[/IMG]
Wheels:
Brand - Weld Evo
Model - Forgestar Chrome
Wheel Diameter - Front: 20X9.5 Rear 20X10.5
Initially, when I bought these wheels in 2005, weld had to supply thin spacers as they made the first batch of rear wheels incorrectly. Subsequently, the rear wheel chrome shattered and flaked and had to be returned under warranty (at my considerable expense). The replacement rears were obviously redesigned in the inter-rim (see what I did there..)and are a little chunkier in design.
Tires:
Brand - Dunlop
Model - Sportmaxx
Size - Front 275/35/20 Rear 275/35/20 (rears aren't wide enough and will be replaced with 285 or 295 when they wear out.)
Tokico D Spec adjustables and Roush lowering springs, SHR rear panel and medallion, Spoiler Store GT500 spoiler and hood scoop, chrome tail-light bezels, Prospeed exhausts.
Can't seem to edit the original post so I've updated the details.
2007 Mustang GT
Wheels:
Brand GT Legends
Model Ghost
Wheel Diameter 20
Offset Front 30mm Rear 38mm
Did you need/use a spacer? No
Tires:
Brand Toyos
Model Proxes 4
Size Front 245/35/20 Rear 295/30/20
Suspension Mods if any
Eibach Pro Kit
Updated! With wheel set #4!!!!!
Wheels:
Brand - Rev Wheel
Model - Cobra 340 Gunmetal
Wheel Diameter(Front)- 18X8.5
Offset - +32
Wheel Diameter(Rear)- 18x10
Offset- +45
Did you need/use a spacer? No.
Tires:
Brand -Nitto
Model - NT555
Size - 255/45ZR18(Front)
295/45ZR18(Rear)
All stock suspension
Now have StangSuspension Series II springs(1.75" front& 1.5" rear), Steeda heavy duty upper strut mounts and Steeda adjustable panhard bar.
NO tire rub of any kind, but the CDC Classic spoiler scrapes a few times/week.
Brand - ??? Got them through Cruzin Concepts
Model - Black Chrome FR500
Wheel Diameter(Front)- 18X9
Offset - +30
Offset- +40
Tires:
Brand -Dunlop
Model - SP Sport 9000
Size - 275/40ZR18(Front)
285/50ZR18(Rear)
Absolutely no tire rub at all:nice:
Wheels:
Brand GT Legends
Model Ghost
Wheel Diameter 20
Tires:
Brand Toyos
Model Proxes 4
Eibach Pro Kit
Aren't those the wheels that Cervini uses?
Can't seem to find the brand all I can come up with is the Driving Simulator GT Legends which incidentally uses the same logo and type :D
Wheels:
Brand - Saleens
Model - Black 5 Spokes
Diameter - 18"
offset front - +36mm (1.42") backspacing - 6.32" (160mm)
offset rear - +45mm (1.8") backspacing - 7.2" (184mm)
spacer - No
Tires:
Brand - Nittos
Model - 555 Extremes
Size - front 245/40/18 rear 285/40/18
Suspension Mods
Steeda Ultralite springs
17" Cragar SS Wheels
Cragar's website, Gallery Section, has a picture of a 2006 Mustang with 17" Cragar SS Wheels "old school Style". I can not find any info on them. Can anyone help.
Thanks
Wheels:
Brand: Roush
Model:Cast
Wheel Diameter: 18 x 10
Offset: 41mm I believe
Tires:
Brand: Dunlop
Model: Direzza Z1 Star Specs
Roush Stage 2, shocks and dampers soon to be replaced by Koni Sports with Steeda HD strut mounts.
Wheels: Toxic
Brand: Tocix I think
Model: 5 spoke Saleen look a likes
Wheel Diameter: Front: 20x9, Rear 20X10
Offset: sorry I wish I knew
Did you need/use a spacer? no
Tires: Proxy 4s
Brand: Toyo
Model: Proxy 4
Size- Front: 255/30R20, Rear: 295/30R20
Suspension Mods if any: None
